Official Forklift Driver
This is what I have in my web page for the A/C:
A/C Clutch Diode.....................Top of RH front of engine, in A/C compressor clutch connector
A/C Compressor Clutch............Top RH front of engine
A/C Coolant Fan Switch...........Rear of engine compartment, on
A/C line
A/C Defrost Valve Vacuum Actuator......................Behind RH side of I/P, on heater and A/C plenum
A/C High Pressure Cut-Out Switch.........................Rear of engine compartment, on A/C line
A/C Underhood Fuse................RH rear of engine compartment, near Blower Motor
Air Divert Valve........................Front of engine, above water pump
Air Mix Valve Actuator.............Behind RH side on I?P, on heater and A/C plenum
Air Select/Switching Valve.........Front of engine, above water pump
AmbientTemperature Override Switch.........................Behind I/P, on rear of C100
Blower Control Module.............Front of dash, in LH side of evaporator housing
Blower Motor............................RH front of dash
Blower Relay.............................RH front of dash, above blower motor
Blower Resistors........................Front of dash, in LH side of evaporator housing
Defogger Control.......................Behind center of I/P, on heater and A/C control assembly
Defogger Relay..........................Behind center of I/P, on heater and A/C control assembly
Heater and A/C Programmer....Behind LH side of I/P, right of steering column
Heater-Water Valve
These were copied from the Helm Service Manual.
For more go here:
Component Locations
Hope that helps. :thumbsup:
