On my '72, the odds are for that pesky 30 amp fuse in that stupid white fuse holder, located just aft of the horn relay/power dist tie point on the drivers' fender liner, it's the high speed fuse going directly to the relay...the holder gets corrosion in there, heats the fuse ends, melts the solder in the fuse, fuse looks good, but it's not....fought this on many a GM car...MY cure for my '72 here was to skin the wire ends, and put under a 40 amp circuit breaker type fuse with screw terminals...you could wire in a 30 amp mini fuse, and be much better off with the attendant rubber holder, either one is fine....
but replaceing with another white factory type fuse holder has proven futile over time, for me...
go figger, must the the new one aint worth a damn....dunno....
:crazy: :crazy: :surprised :cheers:
