Any Ideas? I turned car off and blower motor kept going I unplugged it from under the hood, I have the digital controls and I dont think buttons getting stuck the display changes when I depress a button but im not sure.:crazy:
Blower control module kaput
Is a solid state relay controlled by the HVAC head unit.
Has power direct from batt to blower motor so when faulty can run blower any / all the time.
Try working on your car in the garage @ 12.00 at night and have the blower randomly start up on it's own :WTF
Also check the fuse in the weatherpak hosing on the blower motor; if this is blown can cause motor to run also
"actual blower speed (voltage) is returned to the Programmer on a protected circuit with a 5 amp fuse
If the fuse opens, the default is high blower and it will often run with the ignition off"
Yes that would freak me out the motor popping on at midnight hehe, thanks again will check that stuff out in the morning.
BCM is expensive new ($160 ) but the same module was used on all GM cars ( Caddy's ) with climate control for many years.
BCM location
