1 - 20 of 48 Posts
DC Pit Crew
A lot of guys dread this project because there are a few things that can go wrong and really ruin your day. If you discover significant rust at any of the mount locations it can mean welding on new frame mounts and cage nuts. However, if your frame is generally in fair to good condition I don't think there's much reason to worry. I've tried to be as explicit in this how-to as possible so that those who are on the fence might take the plunge and give it a shot. I'm working on a '69, so anyone with later C3's with soft bumpers have some slight differences for loosening the bumper supports. Alright, lets get started.
First you have to choose which material you want to use for your mounts. From '68 to '72 GM used solid aluminum bushings. Starting in '73 they switched to rubber to soften the ride a bit. Since then, manufacturers have made polyurethane mounts so that's a third option. I opted to replace my aluminum mounts with poly from Energy Suspension. They should last longer than the rubber mounts with a little more forgiveness than the aluminum mounts and they're also a bit less expensive than rubber. Because there is very little movement between the body and frame and the mounts are graphite impregnated there should be no issues with squeaking. You can buy kits at most of the major 'vette part houses that include all the bushings, bolts, washers, and shims you will need to do the project. Here are the kits offered by Zip.
Aluminum ($99.95):
Rubber ($149.95):
Poly ($109.95):
However, I'm a cheapskate so I looked up the Energy Suspension part number (3.4216) for the poly bushings included in the Zip kit and found them on Amazon.com for $40.40 with free shipping. :partyon:
It says the application is for '73 to '82 'vettes, but they fit the chrome bumpers just fine. The poly cushions are .625" thick plus a flat washer that's about .125" thick where the aluminum bushings I pulled out were about .440" thick, but I don't expect the 1/4" ride height change will be very noticeable. Here are the instructions for the kit that shows what it includes:
http://www.energysuspension.com/assets/files/pdf/17050.pdf
So now I've got the bushings figured out, I just need hardware. The original bolts are 7/16-14 about 3.5" long with a tapered tip. The original style bolts in the Zip kits are grade 5 and plated to prevent corrosion. I decided to go grade 8 because they're less than $1 per bolt at the hardware store and I trust the yellow zinc plating on the grade 8's more than typical platings I've seen on grade 5. I bought eight 7/16-14 by 3" bolts, two 7/16-14 nuts, eight 7/16 lock washers for a total of about $8 after tax. The 3" bolts are just about right for the poly bushings. They're long enough to start threading without any trouble, but won't protrude past the nut very far when torqued. If you're using aluminum bushings kit the stock length of 2.5" will be better.
Finally, you'll need a few shims if your originals are shot. Some guys just use fender washers instead of the original style shims, but for $1.00 each through Paragon I figured I'd just get the original style so someone doing this to my car in another 40 years would recognize them rather than thinking they were just extra washers.
Now that we've got parts figured out, let see what to do and how to do it. There are 8 mount locations. One at the front of the birdcage, one below the A-pillar, one at the rear frame kick-up, and one just aft of the rear wheel:
For the purpose of this thread I'll refer to them by number according the above illustration for the driver's side and as #5 through #8 on the passenger side.
DC Pit Crew
Discussion Starter #2
The first step will be to soak the bolts with your favorite penetrating oil. I use either WD-40 or PB Blaster. WD-40 isn't quite as affective, but PB Blaster has a fairly strong odor. You want to squirt them down once or twice a day for a least a couple days to hedge your bets against breaking off bolts or cage nuts. In order to get to the mounts you have to remove a few parts.
To get to the #1 mount you need to remove the splash shield just behind the front tire. This is looking up just aft of the front tire. Front of the car is to the left:
There's the #1 mount:
Mount #2 is accessed from inside the car, so you have to remove the door sill plate, kick panel, and speaker:
Here's a look inside that pocket:
Hopefully yours looks less rusty than mine. All that rust (and the pile of rusty metal chips I vacuumed out before this shot) is a sign of rotting birdcage :thud:. I'm not looking forward to that project.
Mount #3 is hidden behind a small access panel in front of the rear tire. Well, for most people it will be behind an access panel. Said panel was missing on both sides of mine which undoubtedly contributed to the fact that my #3 cushion had completely corroded and was missing on both sides.
The fiberglass damage is from a previous owner who installed the trailing arm bolt from the outside pointing inboard rather than the way you see it there. Thank you bubba :rolleyes:
This shows the missing #3 cushion. You can see the body sitting directly on the frame mount.
Mount #4 is the most accessible in the aft part of the wheel well.
This was the only mount that had any shims on my driver's side. Don't mind all the bits of burnt rubber spackleing the inside of the wheel well :devil:
DC Pit Crew
So now you know where each mount is and how to get to it and you've squirted them down. Now you can start removing and loosening the rest of the components to be able to raise each side of the body about 4 inches. You'll need to:
1. disconnect steering column from box
2. loosen master cylinder and proportioning valve bracket
3. disconnect clutch linkage
4. remove rocker panels
5. remove antenna ground (may not be necessary)
6. remove ground strap on #1 mount bracket
7. remove battery ground (may not be necessary)
8. loosen or remove rear bumper support
9. loosen front bumper support and radiator support
Some of these are more self explanatory than others, so I'll describe each of them.
1. Disconnect steering column from steering box
On stock applications this can be done one of two ways. Either loosen the steering column and pull it upward and inward inside the car to disengage it from the rag joint, or remove the 3 bolts holding the box to the frame and disengage the box from the rag joint. I have a U-joint in place of the rag, but I still ended up removing the bolts holding the box to the frame.
2. Loosen master cylinder and proportioning valve bracket
I didn't want to mess with disconnecting brake lines, so I just loosened the two nuts holding the MC to the firewall and removed the one bolt holding the proportioning valve to the frame. Here's the valve between the control arm and steering box:
3. Disconnect clutch linkage
I don't have a good pick for this one because my whole clutch linkage was out for sidepipe installation. Here's the clutch pushrod coming through the firewall where you'll want to disconnect it:
4. Remove rocker panels
Sorry, no good pics of this either, but it's fairly self explanatory. Just look for the philips head screws along the rocker panel below the doors.
5. Remove antenna ground
This may or may not be necessary depending upon how high you're lifting the body. Here's a pick from another person's project looking at the inner rear driver's fender with the tank removed. Just look for the strap terminating at the frame in that area and remove the small bolt (3/8" wrench).
6. Remove ground strap on #1 mount bracket
Remove the small bolt (3/8" wrench) going through the #1 frame bracket
7. Remove battery ground
This may or may not be necessary depending upon how high you're lifting the body. It's a 1/2" bolt (5/8" wrench).
I decided to completely remove the rear bumperettes because I didn't want them hanging off the body and then have something snag them and damage the body or the bumpers. There are 4 mount locations for each bumperette. You'll need 5/8, 11/16, and 3/4 wrenches and sockets.
I don't carry a spare tire, so I'm not sure how difficult all of this would be to access with the carrier installed. I also completely removed the outer brace seen going to the very corner of the body in the above pic. Don't forget about the bolt just above the marker light! As I said before, I have no idea what this is like for a soft bumper car.
This was a bit of a challenge. There are 4 bolts that hold the front end to the frame that are accessed from the front wheel well.
The first three are obvious. The fourth is hiding behind the bubble in the front bumper brace.
The middle two bolts thread into weld nuts on the back of the frame horns. The other two require you to get a wrench on the nut behind the frame horns. This isn't too bad on the driver's side (I used a 3/4 deepwell socket on the nut and held the head of the bolt with the wrench) but on the passenger side the lower radiator hose gave me trouble. It might be a bit easier to access with a stock radiator. As I recall, the lower hose neck isn't as close to the bottom of the radiator on a stock unit. You will also need to loosen the front bumper from the bumper support so you can move the support outboard enough to get the bolt out of the hole. There's one bolt holding the support to the bumper which you can see through the front grill:
I found a 5/8 socket on the end of a 6" extension reaches perfectly.
Completely remove the 4 bolts on the side that you plan to raise first. Just loosen the bolts on the opposite side. I also supported the front end with a section of 2x4 to keep the whole front clip from sagging.
DC Pit Crew
Discussion Starter #4
We're almost the point of lifting the body, so take a break and go from front to back making sure there is nothing else attaching the body to the frame. I had two seat bolts that went through the frame from my C5 seat install, so I had to remove those as well.
Now that the body bolts have been soaking for a few days you're ready for the moment of truth: trying to break each bolt loose. Hopefully you don't have any trouble and everything loosens up nicely. Remove all the bolts on the side you plan to raise first and just loosed the bolts on the opposite side. That will keep the body from shifting too much, making it difficult to align to get the new bolts in. With all 4 bolts on one side removed it's time to lift. I used a 36" section of 2x6 and cut a few notches in it to clear the tabs on the body of the rocker channels. Make sure it doesn't extend too far forward or it will block access to the #2 mount.
The 2x6 gives you enough room to get the body raised a few inches before the jack pad reaches the frame. The body should lift fairly easily. If you hear a lot of popping and cracking STOP and figure out what you forgot to disconnect. The front end support might take a few whacks with a deadblow to make sure it's not rusted to the frame.
I was doing this before the poly cushions had arrived, so I put some jack stands under the 2x6 and left it jacked up while I cleaned and painted the mounts. Here are a couple lifted pics:
front support:
#2 mount:
Looking fwd down frame rail:
That's all I've got for now. I'll update once my mounts get here on Wednesday and I get them installed. :thumbsup:
Great post - I am looking forward to the next installment. I have had a new set of poly body mounts sitting in the garage for 2 years now, its a job i will get round to one day.....
Where did you get the steering column joint? I have wanted to get one for a while now (I never liked the rag joint).
If you make it look really easy you might inspire me to start my body mounts! :thumbsup:
Lester
DC Pit Crew
Discussion Starter #6
Lester
it's a Flaming River U-joint with an extra coupler to adapt the double D on the U-joint to the spline on the steering box input. The extra coupler and short section of steering shaft ending in a double D are both from Speedway Motors. It was a quick fix when I compressed my steering column during an attempt to install a Jeep steering box and then didn't want to rebuild the column to get it back to regular length. There are some benefits to the rag joint as far as misalignment and not preloading the worm shaft of the steering box or steering shaft of the column, but my column bushings were already in bad shape so I went with the U-joint.
Thanks for the info. Think I will be having a measure up, work out what I need and then put an order in.
I know the rag joint is safe, and even if failed has a metal backup, but its there in the back of my mind. Another little project :thumbsup:
DC Pit Crew
Discussion Starter #8 (Edited)
parts came in today, so I got the driver's side set down on the new bushings and new bolts started. One thing I learned in the process is that the Energy Suspension instructions are a little misleading. The pictures indicate the thicker bushing should be sandwiched between the frame and body, but according to the part numbers the thinner one should be sandwiched. Fortunately the bushings have their part number stamped into them, otherwise I wouldn't have noticed until I had finished up both sides and realized how high the body was. Here are the two bushings next to each other. The thicker #7019 is on the left with the thinner #4072 on the right.
The #4072 is about 5/8" thick while the #7019 is about 1" thick. Put the thinner one between the frame and body unless you want the body jacked up an extra 3/8" :crazy: Unfortunately for me, I didn't realize my error until I had all 4 bolts started and the body set down. Here's the #3 with the bushings in the wrong spots!
In spite of the duplication of effort to jack up the body again and swap the bushings it didn't take very long and I had no trouble getting the bolts to line up and start threading in the cage nuts. The #2 mount is a little tricky, but the sleeve for the poly bushings fit tightly enough to keep the upper and lower bushings in place so I only had to worry about keeping the flat washer from moving while the body was lowered. Just take your time and check the alignment as you set it down. Here are a few pics of #1 and #4 with the new bushings (in the correct positions).
You'll notice that I didn't replace the metal reinforcement that's supposed to be on the body for #4. I would have had to remove the rear inner fender and deal with getting it bonded back in place, so I just made a thin metal plate to help distribute the load a little more than the washer. Not ideal, but it's more than bubba did the first time. However, with the body sitting loosely on the mounts I've noticed that the #1 and #4 bushings are not supporting any weight. The driver's door also doesn't line up with the striker as well as it used to. I attribute this to the body sagging and settling while the #3 and #7 mounts slowly disintegrated. Hopefully it will conform to the new mounts, but I may add a few additional shims to #4 to compensate a bit. I'm also hoping that I will have enough adjustment at the door hinges to get it to line up with the striker better. I'm open to suggestions if anyone thinks I'm crazy on this. :thumbsup:
Many Thanks lsejlowe:thumbsup: ,
I've got my bodymounts and was wondering the best way to tackle this, then low & behold you've done it & with pics too.
Awesome job, I owe you a Beer or 2
(wanna do mine ???:laughing: ).
Again GREAT job THANKS,
GAV
DC Pit Crew
Discussion Starter #10
hell, you fly me down to Aussy and I'll do the whole thing for ya! :laughing:
If you discover some big differences for a soft bumper model feel free to add some pics to this thread.
Planning to do mine. Does anyone see why I should not use stainless steel bolt, nuts and washers? Your input would be appreciated.
DC Pit Crew
Discussion Starter #14
You might be alright with stainless if you don't plan to do any competitive driving, but I think Grade 8's with a good anti-corrosion plating and some anti-seize would be as good against rust as stainless.
Body Mounts
Great job and lots of info... I noticed the rusty number 2 mount
did you replace the rusty section , cut out or were you able to patch it. i was doing my speakers the other day and i noticed the #2 on driver side was pretty bad.
i wanted to know how to repair this thing
thanks jeff
Awesome thread, thank you for this. I am in the middle of this right now. I need some picture of how the tapered bushing goes in the kick panel on #2 & 7 and also in the wheelwell pocket? do the go tapered end down or up?
DC Pit Crew
Discussion Starter #18
thanks jeff
Hey Jeff, sorry I missed this the first time. There wasn't any structural damage around the actual body mount. I just cleaned it up and hit it with some POR15. I'd say just start by cleaning out the body mount pocket to see what you're dealing with. If the whole mounting area is rotten I'm afraid you'll be in for a major project rebuilding the birdcage :thud:
The tapered end goes toward the other bushing, so for #2 and #3 the tapered end points down. It will look just like this but flipped upside down:
I spoke to Ecklers today, and got the correct install procedure for this.
On mounts 1 & 4 , the tapered mount goes between the frame and the body with the taper facing down. On mounts 2 & 3 the puck goes between the body and the frame. The tapered mount goes in the kick panel and in the wheelwell hole with the taper up.
I will post some pictures once i get the frame back from the sand blaster this week.
Grumpy, is it me or did you say that wrong. It seems to me the picture in the previous is the opposite of what you said.
1 - 20 of 48 Posts
