I have all four of the main brake lights that do not work. The 5th small brake light comes on but the four large ones do not. I turn on the hazards and they work fine. I checked the bulbs their good. I checked all fuses and none are burnt out. Can anyone help me out with this?
Try to pull your codes and see what shows up.It's hard to guess.
Theres a brake light switch on the pedal,heres the procedure to change it if thats the problem.
Service and Repair
Removal Procedure
Remove the instrument panel (I/P) lower trim panel.
Disconnect the stoplamp switch connectors.
Remove the stoplamp switch.
Installation Procedure
Install the stoplamp switch.
Adjust the stoplamp switch. Refer to Stoplamp Switch Adjustment.
Connect the stoplamp switch connectors.
Install the instrument panel lower trim panel.
The c5 tunning section has the procedue to pull the codes,and the descriptions as well.No need to buy anything for that.
