1 - 9 of 9 Posts
We all know the Brembo GT Monobloc brake kits are considered one of (if not the best) brake kits you can put on any car (Corvette included). Spend a day at any local track event and you will quickly see how many Vette enthusiasts have upgraded to the Monobloc Brembos. Most high end sports cars come with the Brembo's as OEM equipment.
We have put together the "Brembo GT Upgrade Center"...Only GT Brembo Brakes, 2 piece floating rotors, monobloc calipers, Goodridge SS brake lines, pre-loaded pads, etc....all in one kit specific for your car. Everything listed is the best (other the than GT-Racing kits which are for the professional racer) and is the correct part number for your vehicle.
Organized by vehicle and then by front and rear kits..
Then the best part, every kit is on sale and most all are in stock ready to roll (just in time to get you that last minute X mas gift that you earned all year ;)). Also have free shipping on every kit....
Check it out below....
Brembo GT Brake Upgrade Center
Scroll down to the bottom to choose your vehicle.
Only focusing on the Corvette, Camaro, Challenger, and Viper right now (all worthy choices ;))
any feedback, feel free to let me know....
Jim:cheers:
Discussion Starter · #2 ·
Brembo's performance proven systems result in a substantial improvement in overall braking performance. Key attributes like shorter stopping distances, reduced brake fade, improved pedal feel, and perfect front to rear balance increase safety and build driver confidence.
Brembo's largest multi-piston calipers and 2 piece floating rotors reward even the most demanding driver with “Optimized Brake Balance” and maximum performance. Brembo engineered these systems to be lighter than original equipment brakes to improve steering response and handling characteristics. These traits, combined with increased stopping power and reduced brake fade, deliver truly unmatched performance. The confidence that comes from a Brembo brake upgrade delivers a whole new driving experience.
The Gran Turismo system’s level of technology and performance is unrivaled by any other product on the market. By utilizing larger calipers and discs, thermal capacity and brake torque is increased. This potent combination offers the extreme in Brembo’s leading edge technology for high performance street or track use applications.
Brembo Gran Turismo High Performance brake systems include:
* Brembo 4 piston calipers with sequentially sized pistons; includes color choices of red, black or silver calipers
* Brembo two piece “floating” hat and rotor assemblies reduce unsprung and rotating weight and dissipate heat faster
* Brembo drilled or slotted two piece rotors up to 15” (380mm)
* DOT and TUV certified Goodridge stainless steel braided brake lines; are guaranteed for life
* Brembo high performance brake pads
* Brembo “floating” anti-rattle rotor hardware
* Brembo billet aluminum brackets with aircraft quality hardware.
Brembo brake systems are fully compatible with ABS and traction control systems. All of the necessary hardware is included to insure seamless installation. For more information about Brembo GT Brake Kits check out the Brembo Upgrade Center
Jim:cheers:
I really like my Brembos. I could not beleive the car could stop as fast and short as it does now.
1 - 9 of 9 Posts
