Does anyone have experience with converting the manual lock and latch mechanism on the C3 vette to a electric/solenoid/actuator/keyless entry styled system?
Yes. Did it on my 72. I left the door handles as stock. Just added the door lock solenoid to each door's lock linkage. Then I controlled them like Gm does their power locks. I used a Radio Shack car alarm with keyless entry to control the lock and unlock relays. I think it was around $200 then for me to do it. J. C. Whitney has cheaper lock solenoids then what I used. Keyless only modules from them is at most $39. I didn't catch the year of your car but if you go with the alarm option don't hook up the voltage sense part of the alarm on the older C-3's because when the clock rewinds it pulls enough current to trip the voltage sense.
Read the rest of your post. I think you could add lock solenoids to the door handle. Then you could pop the doors with a keyless lock module. Haven't did this to mine however.
Do you remember how many lb. pull you have on your solenoids? I've heard anything less than 35 or 50 and you'll be replacing them in less than a year.
I can't remember the lbs. pull for the solenoid itself. The lock mechanism for the doors did have to be reworked. The control rods have rubber anti-rattle cushions around the rods in a couple of areas that I did shave down to lessen the drag that they made. To make the solenoids release the door catches, I don't have a clue on the pull these rods have. I can't see why it would be excessive.
