Hey guys, I just order my rim/tire combo from AFS. I got the silver ZR1's w/ 11" rears. Is there a fuse I can pull to disable the LTPWS? I won't be using this with the new rims.
I have a 96. I think your fuse panel is on the side of the dash at the passenger side? And you have to open the passenger door to get to it?
If so, if you take the cover off the fuse area, the backside of the door should tell you where everything is at.
Is it listed?
I'll check, from what I've been told you can pull the cruise control fuse and this will eliminate the system. I've also been told it can be turned off with a tech 2 scanner. I'll check my service manual when I get home. I hate to have to pull the bulb, but if thats what it takes.
