1 - 8 of 8 Posts
On a 2005 C6 what wire do I need to hook to to get Cobalt boost and fuel gauges to dim (white wire from gauge). Where can I find it and what color is it
THANKS RAYZZZ MY CORVETTE LIKES MY MONEY
The dash light control is the button to the lower left of the dash. To the left of the steering wheel, next to the air vent. You could probably tap into that switch since it controls the dimming of the dash lights.
found it
I found the wire. On my 2005 C6 at the dimmer switch the wire is brown that gets 12 Volts when the headlights are on. Hooked the gauge up and works great. I wonder if I were to use one of the other wires would it dim. :cheers:
Not so
Also the white wire on the gauge just makes it light up. I thougt it would be lit already and when the white wire got 12 Volts the gauge got darker. Not so.
it does make it dim
The brown wire on the dimmer switch hooked to the white wire on the Colbalt gauge allows it to be dimmed. All you have to do is turn the dimmer down and gauge and instruments all get dim. Weeeeeeeeeee: :buhbye:
My dimmer switch on my 06 doesnt do ****. Ive turned it both ways and the dash lights never change, they are either bright with the headlights off or slightly dimmed when the lights come on. I have no control over them and the owners manual says nothing??? WTF???
New 2010
SORRY i FORGOT WHERE TO POST. BEEN GONE SINCE THE CHANGE OVER FROM PATRICK. i did buy a 2010 brand damn NEW JUST LIKE i FINALLLY WANTED. BASE: 3LT:smack ALL THE STUFF ARCTIC WHITE/CASHMERE. 1610 MILES ON IT NOW. GOT IT JUN 18, 2010. jUST TRYING TO LEARN THE PADDLES, ONSTAR CAME WITH IT WORST SOFT WARE IN THE WORLD. I ALWAYS HAVE TO GET HELP TO DIAL BECAUSE IT CAN NOT RECOGNIZE NUMBERS. PLUS THE AVERAGE AGE FOR CUSTOMER SERVICE IS ABOUT 22. SCRERW'EM.:smack
JUST HAD THE NITROGEN DEAL DONE BUT I'M IN HJEAVEN FINALLY.
'08 GUY
SORRY I USED YOUR POST BUT HAVE FORGOTTEN HOW TO POST NORMALLY
WWR
another aggravaTING BUTTON I found it takes patience( idon't have) and a delicate turning to get them the brightest.
Sort of like touching that special place on a woman.
'08 guy
1 - 8 of 8 Posts
