Boy, I REALLY hope everything that they're doing with your car is on the up and up(considering the crazy crazy LOW prices)......I have to assume that since they told you that they bored the block 60 over for some new 60 over forged pistons, that they also installed new cam bearings after they cleaned everything and started the bottom end re-assembly.....properly pressing in all new cam bearings and then immediately having a problem with them upon the initial startup sounds VERY VERY suspicious(not to mention them stringing you along on the finish date over and over again)....I've been putting cam bearings in motors for close to 20 years and have "never" had anything go wrong with a properly installed set of cam bearings.....it seriously sounds like they don't have much experience in what their doing, or at the very least, they're not very good at it(or checking VITAL things along the way).....reguardless that the guys working on your car are a "friend of a friend"....I would seriously watch them like hawks from this point.....point being: if they are telling the truth and they had this kind of issue with a cam bearing, there may be several more serious issues to follow.....I understand that your not very familar with what all is involved in block machine work and the proper engine assembly technics, but building an engine "correctly" is "nothing" at all like just having some machine work done and bolting on parts.... which is really why I just recomended that you let them take care of the top end(heads and cam) and not unnessarily touch your good condition bottom end........I would also tell them you'd like to know ALL of the specs that they set your bottom end up at...IE: PISTON RING END GAPS, PISTON TO CYLINDER WALL CLEARANCE, ROD SIDE CLEARANCE, ROD BEARING CLEARANCE, MAIN BEARING CLEARANCE, VALVE TO PISTON CLEARANCE, WAS THE BLOCK DECKED? "and if so" HOW MUCH IS YOUR NEW PISTON IN THE HOLE?, WAS THE CAM DEGREE'D IN?, OR JUST THE TIMING DOTS LINED UP?.....and I would also ask the BRANDS and PART NUMBERS of EVERYTHING that they used.......if they have fairly quick "honest" answers to these questions (which they definitely should if their not just slapping things together and BS' ing you) ,this will atleast give you some piece of mind about the quality of the engine build you paid for and what your engine has in it incase further problems arrise.......post their answers to these questions or send me a PM and I'll tell you if things sound correct(and within spec)..........good luck with everything...............Joe:thumbsup:
