need to know if these specs will work on a stock motor with out doing any changes to the ecm and prom i do not want to mess with that at all
Camshaft Specs:
Valve Lift Intake: .420
Valve Lift Exhaust: .443
.050 Duration Intake: 204 degrees
.050 Duration Exhaust: 214 degrees
Overlap: 51 degrees
Intake Centerline: 107
Exhaust Centerline: 117
yes they should work but they also won,t provide the max benefit you could get, heres crane cams version, and its popular swap on the earlier 1984-1986 vettes when your concerned about compatibility as its a boost over factory with no bad side effects
http://www.cranecams.com/index.php?show=browseParts&action=partSpec&partNumber=114122&lvl=2&prt=5
heres a bit more radical cam, that will also work ok, but as crane suggests its best when used with an adjustable fuel pressure regulator and a 3.54:1 or 3.73:1 rear gearing that helps it noticeably, as the stock rear gear is a restricting factor
http://www.cranecams.com/index.php?show=browseParts&action=partSpec&partNumber=114132&lvl=2&prt=5
