Olay I had an oil that I thought was the cam sensor due to blow by oil up front. After taking intake off it turned out to be pcv hose behind intake. When I put everything back together I have a noticable hissing sound from passenger side intake. Any ideas?
Yes. I double checked just to make sure, but somehow that small little hose came off.:thud: The only good thing is the engine is clean and I might not get so messy taking intake back off.
Sounds like it's the vacuum that goes to the climate controls. It's a small line that is behind the intake more towards the passenger side of the engine.
Try changing the direction of the air output inside the car. If it wont change, then you left that unplugged.
