Okay, I have looked and looked. I know there have been some threads about the procedure for extinguishing the change oil light....but I'll be dadgum if I can find it now when I need it. I have a 95 LT1 vette convertible. Can someone please tell me how to turn that oil change indicator off???? Thanks. Can't wait for Bloomington Gold!!!!
1. Turn the key to "RUN", but do not start the engine
2. Press "ENG MET" on the trip monitor, Then, within five seconds, press it again
3. Within five seconds, press and hold "GAUGES" on the trip monitor. The "CHANGE OIL" light should flash
4. Hold the "GAUGES" button until the "CHANGE OIL" light stops flashing and goes out. This should take no more than ten seconds
When the light goes out, the monitor is reset. If the monitor does not reset, turn the ignition off, then try again.
That should do it!
Steven
Thanks
Thanks Steven. I will give it a try later tonight. Are you going to Bloomington Gold? If so, which days? I will be there Thursday I think. Sometime this summer we should have a cruise! DaLE
