Any of you guys seen this on your C5? I started getting it a few weeks ago sometimes when starting the car... then I noticed that even if I didn't get the charge fault, I wasn't seeing the "Corvette by Chevrolet" message either. If I turn the key on and wait to start the car, I get the .... by Chevy message and no fault message. Some dude on another list suggested that the computers must go through their own startup process, which actually makes a little bit of sense.
I thought I'd check in with the wisdom on this list and see what ya'all think.
Thanks,
Michael :buhbye:
YES! YES! YES! I was told that the battery might not have a full charge? BS! It won't throw a code either. Happens when the car has sat over night and some times when starting after work. If you figure it out, or yuor dealer does, lemme know and If I find out I'll be sure to let you know. I did check all battery connections, I had been told that the battery cable may be loose. I started seeing message intermittently at about 500 miles, have 1700 on now.
