minimum three coats, maximum five...depends on how much you have to sand off each stage (coat) to level it and how ''wet'' each stage is applied.. .don't pile on too much clear --too much paint build will cause ''cracking'' when the paint reaches ''full'' cure, which may take up to a month, depending primarily on type of paint used, but painter technique and weather also affect
