Blower not working after being removed and reinstalled. I took the blower out again and did some testing. I bench tested the blower and it works fine. I checked for voltage at the blower connector and it's 13.2 with the engine running and the A/C on. I connected the blower outside the housing and activated the A/C and it worked. I partially installed the blower and tested again and it worked. I fully installed the blower and it worked for a few seconds and then nothing. Manually changing the blower speed has no effect. Does that only leave the blower speed control or the climate control? Is there anything else it might be?
When you partially installed it, did you hook it up with the climat4 control or direct?
I connected it to the wiring harness speed control. When I say partially install it I mean I did not tighten or insert all the screws. I made sure there was no interference and started the engine. The blower worked as it should. I should add I reset the HVAC by removing the fuse for several minutes when this first happened to no avail. I am considering disconnecting the battery for a while and resetting all the computers. I just need to make sure there is nothing special I need to do. The car has 35,000 miles on it and I have been unable to use it much for several years. It's time to sell it and I would like the climate control functioning when I do.
103125
