Clutch for L46 (removed) flywheel replacement required ..? (+picture)
Dear all,
My clutch said me bybye this WE, and I'm really embarrassed because I want to repaire quickly my car for Lemans next month (I'm from France)
My engine is a 1970 L46 / CTH so : manual 4 speed gear box.
I a looked on summit and I am completely lost with the huge number of clutch. I've you got some advice for a stock engine (maybe a LT1 cam in the future)
Other question, the most important ! I need to order at the US this clutch, and want to do it during one week end (I'll borrow a repair shop machine to lift the car and work under it) so are all the small block engine fitted with the same clutch ? or do I need to be careful ?
If I give you the number of the gear box, are you able to give me the right number clutch, or do I need absolutely to remove the old clutch before buying the new one ? to avoid mistakes ?
Thanks in advance for your answer.
Hello Liam :)
I managed to remove the clutch, it's was more easy than I though ! :) I like doing mechanics on the C3 it's interesting and well designed.
I've ordered a clutch on Ecklers same as you've shown to me for my car (a 11" & 10 splines) mine was completely worn ..
I've got a question concerning the flywheel, do I need to replace it because of the little heat crack ? will it make chatter / or be dangerous ? or can I just machine it to have a good surface and it will be fine ?
Here is a picture of it :
That is something i haven't seen before, I'd be replacing it.
if a piece of flywheel let go at high RPM it could take your leg off.
Take it to a driveline specialist for advise if no one else posts here for you on this.....It could be just surface damage that can be machined.....like I said it isn't something i've seen before.
Liam
although both the flywheel and clutch should already be individually balanced when you buy them, it would be best to have them balanced as a pair. Then they should be marked so after any future disassembly they can be re-assembled in the same orientation to maintain that balance.
Discussion Starter · #9 ·
ok, I'll think of this, one of ma colleague has a driveshaft to balance and I'll give my flywheel and clutch at this time.
But are the sold clutch and flywheel already balanced, and will I feel the vibration or are there risks to not balance as pair clutch and flywheel ?
Other question, if I balance again the flywheel can I grind it before to light it ?
Personaly I wouldn't bother with balancing and if you want to go with a lighter flywheel, they are available off the shelf.....cheaper freight:lookinup:
Discussion Starter · #11 ·
as you said .. this morning I had an email of Eckler ... 370$ for shipping = cold shower.
I'll compare with Corvette Central, because they pruposed me two different ways of shipping for my last order ... one at 80 and the other at 250$ ... maybe they'll be very cheaper than ecklers with their first shipping method.
I'm looking to buy the equivamlent part and I found this : http://www.parts123.com/parts123/yb...50MDYGU19425024350G~Z5Z5Z5YES~Z5Z5Z50000050G#
Do this flywheel is a lighten one ? Are the interfaces standard ? I see that it's for LT1 and my car has a L46, are the interfaces the same ? It seems to be dependant only on differential ratio (M22) and not the kind of clutch (mine is 10 splines 11")
