I got the Vett back on the road today kinda I put the new trans back in and took it for a spin First I still trying to get the TV cable Adjusted the car will not shift.
I also getting code 42 and 44 I looked them both up I can Find the (EST) Electronic Spark Timming on mt !986 Vett where is it what looks like.
The next code is Code 44 I know where the O2 Sender but why it it showing Lean.
The Car started run very ruff almost died I limb back home it died pull in to the garage ???.
It has a aftermarket Chip In the car due to the motor mods could this be my problem or where should I be looking at now.
On my car, it is a single tan wire near the brake booster.
I would set the timing first and erase that code by unplugging the battery.
However, lean code tells me that it might be a short in the left bank injectors. Check for pulse with a noid light on all the left side injectors. Also check what the ECM is seeing by either using a scanner or tapping into the O2 sensor.
