Code 42 (1986 Vett)
So far what I know its Electronic Spark Timming (EST).
Anyone else out there has had this problem and what did you do to fix it.
Before the Motor swap I didn't have this code after the new motor is in i getting code 42.
No other codes before motor swap either.
I checked the plug it was pluged in but I double check everything this comming weekend.
Did you unplug that when setting the timing? Are you sure you plugged it back in?
Discussion Starter #4
Fixed
Fixed the code 42 it was a broken wire behind the distributor not fun to fix but it done.
I also swapped out the O2 sender no more service engine lights.
With what? Hopefully a good quality heated one not some cheapo at the parts house. I chased a lean problem for a while.
Discussion Starter #7
I installed a Bosh O2 sender.
Now I chasing it dont what to idel and a oil leak it looks like the rear main seal leaking it a 2 piece I going to try to drop the Oil pan with the engine still in the car I hope it works.
