What do you guys think of the Comp Cams Pro-Magnum 1.85 Rocker arm set? I am considering changing the intake to a FAST, and going with these rockers. Along with my other mods, Headers, CAI, and Tune, it should put me real close to 400 rwhp which has been my goal. The car is advertised to have 400 hp I just want it to the rear wheels. I think this is where I will stop the engine mods. But looking for opinions. Thanks
Blurb
With the Pro Magnum Rockers you get the best of both worlds. Pro Magnum Rockers are made of 8650 chromemoly steel. This material is some three times stronger than 7075-T6 aluminum which is used for most aluminum rocker arms. Our engineers used advanced computer technology (including Finite Element Analysis) to refine the Pro Magnum Rocker. We added strength where it was needed and reduced mass in low stress areas. The result: Pro Magnum Rocker Arms have less weight (5%) at the valve than most aluminum rockers. This means more RPM and valve train stability.
Blurb
