Wanted to see if any one knows what might be causing my drivers side window to creak when I open the door or move it side to side. It works fine, but the noise is annoying. Wanted to see what I might be in store for to get it fixed. It's a 1999 Pewter. Thanks in advanced for your comments.
Well don't move it side to side...:laughing: J/K
Its hard to say with out hearing it. Maybe some one on the
forum has had the same trouble, and will jump in.
Creaking Window
Hey Man,
Don't Feel Bad My 01 Pwtr Does The Same Thing. I Havn't Had Time To Do Any Research As To Why, But If I'll Let You Know When I Do
If you get creaking with the window in the up position when you open/close the door, then you may want to try applying grease to the 2 window stops. It worked for me. I removed the door panel to get at the stops.
