I'm a recent member and have been spending a lot of time reading many of the posts. :thumbsup: And have learned a great deal about my C4 in the process.
The problem I am having is with the cruise control. It has never worked since I purchased the car. I checked for vacuum leaks, checked vacuum break switch, replaced break lamp switch, and checked the resistance values on the servo. I thought I found the problem when I disconnected the connector from the steering column control unit. It is a two prong connector that has a conductive film on each side (effectively 4 connections). One of the sides pealed back and therefore no connection on that side. After jumpping the connector I am now getting power to the servo. After a test drive still no cruise control! :huh:
Can anyone tell me where the Cruise Control Module is located?
