1 - 1 of 1 Posts
http://www.hastingsinc.com/Service Tips/cylinder_bore_refinishing.htm
http://www.babcox.com/editorial/ar/ar90058.htm
http://www.aera.org/Tech/tb687r.htm
http://www.babcox.com/editorial/ar/ar110060.htm
http://www.automotiverebuilder.com/ar/ar129832.htm
http://www.babcox.com/editorial/us/us20114.htm
http://www.automotiverebuilder.com/ar/ar49852.htm
http://members.aol.com/carleyware/library/honing98.htm
http://www.babcox.com/editorial/ar/eb110242.htm
http://www.reconengines.com/clip7.html
http://www.nightrider.com/biketech/hdcylinderbores.htm
http://www.circletrack.com/techarticles/82438/
http://www.sporttruck.com/howto/40619/
I would highly suggest that you buy and install NEW 280 or 320 GRIT STONES,(which depends on the rings used) if you BORROW a HONE, and you inspect them frequently and NEVER run a HONE DRY! I normally use a LOT of water from a runing hose while honeing a cylinder, then I totally re-clean and dry , and totally oil the block. don,t forget that to hone that engine properly you should have torque plates in place and torqued in place
http://www.yother.com/plates.htm
1 - 1 of 1 Posts
