hood stuck??
http://www.ecklers.com/product.asp?pf_id=32206&dept_id=1100&mscssid=KP7AD48Q6TSR2L8F00N0SM2EPKN82A2F
heres the tool to open the hood,if its so stuck that it won,t open, once its open ,then check that the latch connector cable is opperating correctly and both slide latches fully retract when the release is pulled, if they do and the hood still does not pop open ,the hoods not centered correctly losen the bolts that hold the spring catch latch mechanism on both sides of the car , (ONE AT A TIME starting with the passenger side first, shut and open the hood then tighten the latch in its new slightly differant position, oil the latch mechanism with MOLY SPRAY OIL
http://www.msmoly.com/
then DRILL a 1/4" drain hole in the lower hood latch support brace to let water drain as thats one of the main causes of rusted and stuck latches (water sitting traped in the latch support then do the driver side,shut and open the hood then tighten the latch in its new slightly differant position, oil the latch mechanism with MOLY SPRAY OIL
then DRILL a 1/4" drain hole in the lower hood latch support brace to let water drain , recheck the connector cable adjustment and that the latches on both sides fully retract when thec latch is pulled, if you followed instructions it should now work
