101 - 120 of 146 Posts
Discussion Starter #101
Scole Bandit said:
Dear Parrot,
Rush Order:
How do I get redC6 banned?
I need an answer in 99 words or less cause if it takes a hundred I am screwed.
Bandit
Dear Scole Bandit,
What you could do is send Patrick a PM asking him if you send him 10 thousand dollars via Paypal will he make you an administrator of DigitalCorvettes.
If so, when you get your duties approved, then ban the person you want off DigitalCorvettes!
:laughing:
Thanks for writing in!
Z06 Parrot said:
Dear Scole Bandit,
Flocking is parrot language for $#*^ing!!!!!!!! LOL
And as for why I talk to Stanley that way?
Because I can!!!!!!!!
:laughing:
Thanks for your questions!
Dear Parrot,
You skipped the banning question!!!!!!
Hurry!
Bandit
Discussion Starter #104
coolhandluke said:
Dear parrot why am I so Dense:bang
Dear Coolhandluke,
Let's explore denisty:
DENSITY is a physical property of matter, as each element and compound has a unique density associated with it. Density defined in a qualitative manner as the measure of the relative "heaviness" of objects with a constant volume.
For example: A rock is obviously more dense than a crumpled piece of paper of the same size.
A styrofoam cup is less dense than a ceramic cup.
Density may also refer to how closely "packed" or "crowded" the material appears to be - again refer to the styrofoam vs. ceramic cup.
Density Comparison to Water: In chemistry, the density of many substances is compared to the density of water. Does an object float on water or sink in the water? If an object such as a piece of wood floats on water it is less dense than water vs. if a rock sinks, it is more dense than water.
Oil and vinegar salad dressing: The oil floats on the vinegar water mixture, while the solids sink to the bottom.
Oil spills: What happens when an oil tanker leaks on the ocean? The oil floats on the water since it is less dense, and this provides some opportunity to clean up the oil spills by skimming the oil from the surface of the water.
Ice: Everyone knows that ice floats on water, but did you know that this is an abnormal physical property of solid/liquid state of water? The more normal physical property is for the solid of a compound to sink in its own liquid.
In order to determine the density of an object, it is necessary to know: the mass, the volume of the substance, and the definition of density.
Density = mass (g)
volume (mL)
Example: Calculate the density in g/mL of aluminum if a 50 mL block weighs 135 g. Solution:
Apply the definition:
Density =
135 g = 2.70 g/mL
divided by
50 mL
If the density of a substance and either mass or volume is known, volume or mass, respectively, can be calculated using either simple algebra or dimensional analysis. The density must be translated as a conversion factor.
Example: Calculate the mass in a 200 cc block of Titanium with a density of 4.51 g. per cc. Solution: The density translated as a conversion factor is:
4.51 g = 1 cc - "per" is equivalent to an equal sign.
200 cc x
4.51 g = 902 g
divided by
1 cc
I hope this helps answer your question!
Z06 Parrot said:
Dear Coolhandluke,
Density = mass (g)
volume (mL)
Density =
135 g = 2.70 g/mL
divided by
50 mL
200 cc x
4.51 g = 902 g
divided by
1 cc
:huh:
Scole Bandit said:
Dear Parrot,
Hurry!
Bandit
Hey,
what did I do? Maybe I got chosen to recieve a certain pic??
stanleyp said:
PARROT WORKS AS A STOCKBROKER!!!!!!! :surprised
:rolling: Parrot what stock should i buy for a grand that would gain me at least 100% return?
Discussion Starter #112
Re: dear parrot any new hot I P O ,s on the shelf
cosmo said:
ready to soar up the chart [tha you know of ]
cos =i want to make a score
Dear Cosmo,
No stock recommendations at this time, but when I get one I will let you know immediately so you can get in and make big dollars!!!!!!!!
If Patrick was selling stock for DigitalCorvettes then I would tell you to buy!!!!!!!!!!
:laughing:
Discussion Starter #113
Re: dear parrot would u recomend GM at these lower levels
cosmo said:
Dear Cosmo,
I would not go in GM until we see what the sales look like for the 2006 year which includes the Z06. They haven't even talked pricing yet for that particular model.
Thanks for your question,
the parrot
Dear Parrot,
This weekend I am hosting an 8 person dinner party. The main course(s), some of my guests do not like lamb, will be chicken marsala, minted lamb with a nice cranberry sauce, asparagus, rice pilaf and baby new potatoes. M question, what is a good wine to serve with the meal? Or should i serve two wines, red and white? I don't normally drink wine... So I don't know.
Yours Truly,
wine-less in knoxville
Discussion Starter #116
msterri said:
Dear Parrot,
Yours Truly,
Dear wine-less in knoxville,
Excellent question and I think I have an answer. Wow, sounds like a great dinner party you are having. That's great!
It is always best to keep wine selection simple. Doing so makes it so much more enjoyable without all of the hassle.
Wine and Food Pairing Tips: Three Easy Steps
1. Drink what you like. Always a great place to start. If you are fond of full-bodied California Chardonnay or lighter wines from Beaujolais, consider drinking it with your meal. Throw out the wine and food rulebook and drink what you like. I have found pleasure in drinking most any wine that I am fond of with good food and good company.
2. Match the weight of the food to the weight of the wine. A simple concept, lighter foods tend to pair well with lighter wines. A light fish dish, or a simple salad paired with a light crisp white such as Pinot Grigio or Muscadet usually works well. Conversely, full-bodied dishes such as veal stew or a New York Strip steak work well with richer wines such as Zinfandel and Cabernet Sauvignon.
3. Be adventurous! We often enjoy the wine experience because it gives us the opportunity to explore new flavors and tastes. The same can be true when selecting a wine to go with your meal. Go wild! Go crazy! If you’ve never tasted a wine from Rioja, a Pinot Gris from Alsace, or a Pinotage from South Africa and you see it on the list, you might well consider it as a selection.
Serving Temperature
Your enjoyment of any wine can be enhanced or diminished by the temperature which it’s served. All too often, we are served red wines that are too warm and are literally “cooking” high above the back bar, or alternatively we are presented with white wines that are brought to the table freezing cold. Warm red wines will be perceived as course and alcoholic, while overly chilled white wines will numb your taste buds and all you will taste is acidity. Most red wines should be served at a temperature of 58 - 68 degrees. Whites wines are best enjoyed at a temperature between 40 - 55 degrees.
Wine by Body and Style: A Short List
Sparkling Wine
Champagne, Cava and Prosecco
Light White Wine
Pinot Grigio, Pinot Blanc, Muscadet, Soave, and Vinho Verde
Medium-bodied White Wine
Sauvignon Blanc, Macon-Villages, Pouilly-Fuisse, Sancerre, Pouilly-Fume and Village White Burgundy
Full-bodied White Wine
Chardonnay from California and Australia, Premier and Grand Cru White Burgundy
Fruity Whites with a Touch of Sweetness
Riesling, Chenin Blanc, Vouvray, and Gewürztraminer
Light Red Wine
Beaujolais, Gamay, Chinon, Bourgueil, Dolcetto and Barbera
Medium-bodied Red Wine
Cotes-du-Rhone, Pinot Noir and Chianti Classico
Full-bodied Red Wine
Bordeaux, expensive area specific, Cabernet Sauvignon, Hermitage, Cote-Rotie, Chateauneuf-du-Pape, Merlot, Syrah and Premier and Grand Cru Red Burgundy
Sweet Wine
Sauternes, Late Harvest Riesling, Muscats, Hungarian Tokay, Port, Sweet Sherry, and Madeira
Good luck and have a great time!!!!!!!!!!
Thank you for your question!
dear parot have u ever experienced the
contintal stock wine [M D 20/20] and what kind of mood atmosphere do you think is applicable
yours truly cosmo
Discussion Starter #118
Re: dear parot have u ever experienced the
yours truly cosmo
Dear Cosmo:
Hasn't everyone experienced 20/20?
Mad Dog, also known as MD 20/20, is a fortified wine produced by Mogen David wineries. It is available in various flavors, such as "Pink Grapefruit", "Wild Berry", and "Hawaiian Blue".
The original “Red Grape Wine” flavor is the only one to have the highest proof of 18%, whereas the alcohol level varies for all other flavors.
Here is one of the parrot's favorites!!!!!!
Mad Dog Shot recipe
Scale ingredients to servings
1 oz vodka
1 tsp concentrated raspberry syrup
2 - 5 drops Tabasco® sauce
Pour the vodka into a shot glass and add some raspberry syrup (should be concentrated, look for it at a Polish section in an international supermarket). Add a few drops of Tabasco hot sauce., and shoot.
As for what mood or atmosphere is appropriate?
My favorite would be sitting on the pool deck on a large cruise ship sipping away at the Mad Dog and then later hitting the casino to shoot craps!!!!!!!! Thanks, for writing in!
:drink:
Discussion Starter #119
Why does it appear I am get owned frontwards, backwards, sideways, and diagonally?????
Why is there a boot up my rear end?????
Why am I have horrible nightmares and dreams?????
Why am I on high doses of Haldol, chlorpromazine, lithium, resperidone, and olanzapine??????
Why do I continually hear voices talking to me???????
Why do I find myself talking to an imaginary friend?????
Why do I think someone is watching me right now?????
Why? Why? Why?
Thank you,
Z06 Parrot
:drink: :drink: :drink: :drink: :drink:
