I came out to the car yesterday and noticed a new puddle under her near the rear (im used to puddles in the front). After a little cursing, i jacked it up and took a closer look. The front seal of the diff is leaking slightly. I can imagine what happens when I run out of fluid in there, so what are my options? Is there a refill hole in the diff case somewhere? How big a job is it to replace what is broken?
I figure at least I have to take out the drive shaft. Can everything else be done while its in the car?
Thanks in advance guys.
Thanks. The one time I dont do a search. :toilet
· Supporting Vendor
Follow that post. Be sure to witness mark the yoke and nut if doing this on the car. Check the pinion yoke OD you may need a speedy sleeve. Use #2 on the splines. I should have all that in the post.
Im hoping I get a chance this sunday to tear into it. I just got the thing driving well so its painful to put it back up onto stands.
:down:
