I am ready to fire up Awesome today. I omitted to insert the crankcase
section of the dipstick retainer. I have the upper part in place though.
Is there a problem here or will it still give an acurate level reading without
any danger of the dipstick touching the crank,etc. Also, the only
gearbox oil available here is 75/90 but it is part synthetic, is that a problem or okay to use.?
The lower part of he dipstick tube provides a guide so the stick stays out of the crank, and also give it some support. Gently work the upper tube out and then install the lower 1/2..
That gearbox oil will be fine..
You're almost there!!
