Well folks, it's been 2 years in the making (or actually in the procrastinating)!
So, when you get in the car and start it up, is this what you see?
When you check you digital information center (DIC), you also see this:
Actually, these reading are impossible because a engine cannot make more oil pressure than the engine is designed to make. It can loose oil pressure, but it cannot create more.
To verify that your sensor has gone south, do this. Turn the key to the on position but do NOT start the car. Your oil pressure gauge will sweep and settle back to zero. If it does not settle back to zero, then you know your sensor or gauge is bad because a engine that is not running cannot produce oil pressure.
On the flip side, if your gauge stays at zero after you start the car and your engine doesn't sound like a 800 pound gorilla is knocking on the hood, then your sensor or gauge is probably bad. If your engine has no oil pressure, believe me, you will quickly realize it! The gauges very, very seldom go out in these cars. The sensors, however, are notorious for failing. Once you replace them, they have been known to go out again rather quickly. This could be from guys over-torquing the sensors during the install (gorilla torque is not needed once during this repair). I don't know as I have not repaired a hundred of them but the reason I relocated mine is because I don't want to have to deal with this repair again. Now my EOP sensor repair is a 10 minute job, not 2 days.
I have been putting this off for so freakin' long that it ain't funny. But since my dead oil pressure sensor (OPS) starting leaking, it was time to get this DIY out of the way. It had started to drip on my exhaust and stink like burning oil (duh). That was the point of no return for me, it had to go! Plus, I have been promising to do this write-up for the longest so this is for all the guys and gals who have been patiently waiting.
Tools Needed
The tools you'll need are not all that uncommon, however, there are a few "must have" tools that will make the job MUCH easier. The engine oil pressure sensor socket is a 1-1/16 deep socket:
Also, the tool needed to separate the fuel line from the female quick connect fitting:
Note the E & F sizes on the packaging.
A small pick or small flat-blade screw driver comes in handy during this repair so add one of those to the list.
Lastly, hose clamp pliers are another thing that will make this job a lot easier too. If you don't have a pair, get some. You'll thank me later.
I'm going to write this as close to the eSi GM Service Manual as possible. That is what I used and it is usually 99% dead on. You may or may not find a short cut here or there but after doing the job as the manual states, I can see why the instructions are written the way they are. The instructions called for the manifold and the fuel rails to be removed as 1 unit. If you are not replacing the manifold, this makes perfectly good sense as you don't want to go and break the fuel injection connections if it is not necessary.
At first glance, this is a very daunting looking repair. In reality, it is not that bad at all. The service manual calls for less than 2 hours for the whole job but keep in mind that those numbers are in a shop with every tool and a lift for the car. That's also for someone who knows what they are doing, which is NOT me. I think I could do it in 4 hours now, but then I'm very slow and methodical with my repairs and upgrades. That's why they work the first time.
So as you sit here wondering if you should even try this, note that I am NOT a mechanic by any stretch of the imagination, I can't identify half the crap I took apart, it took me 2 days to do this and I was scared to death to turn the key once I was done.
So there, you have company. :laughing:
Now for the repair!
Replacing or Relocating the OPS
1. Drain the cooling system. In order to do this, you will need to raise the car. for those who don't have a lift, here's the way I do it.
There is no need to raise the rear of the car. You just need to get the car high enough for you to roll under there and loosen the drain cock.
The actual draining of the system is pretty easy. You simply loosen the drain cock (hey, I didn't name it... that's what it's called) and you will see the fluid begin to flow. You will turn it counter-clockwise. Do not completely remove the drain cock, just loosen it until the antifreeze starts flowing real good. Now go have Dagwood Pizza and your favorite drink because it will take the fluid a little bit to completely drain..
After the system has drained, close the drain cock (don't break it with the pliers by putting the gorilla torque on it), and lower the vehicle.
At this point, you need to remove the air bridge. Every since I learned how to remove my air bridge/filter as a unit, I've always done it that way. After you do it once, it's real easy to do it that way. Instead of posting the pictures here making this DIY even longer, here's another write-up that I did that shows how to remove the air bridge and filter as a unit. Do this before proceeding, or just remove the air bridge by itself.
2. Remove the fuel rail covers. For those who may have never done so, they simply pop off. Just give them a good, careful tug. Each side is slightly different. Here's a shot from the manual. For orientation purposes, the arrow depicts the front of the car.
In this write up, you will notice that I also removed and cleaned my throttle body. Most guys are not going to go through all that trouble to clean their throttle body but you all know me (most guys just leave it attached to the manifold). Thorough is my middle name. If I'm tearing something up, then I'm going for broke! Thus, as you read these instructions, I'll supply pictures from the manual if necessary as my throttle body was removed first before I started this repair.
At this point, you want to clean the area around the manifold where it meets with the aluminum heads. The reason being is a lot of you will have all kinds of gunk and dirt under your fuel rail covers that has probably never been cleaned. You do not want this dirt and crap falling into the engine block! You can used compressed air if you have access to that, however, I used brake parts cleaner followed immediately with a low flow of water from the garden hose. Brake clean will loosen up and remove ANY kind of dirt but it is a expensive way to get your motor clean. You won't have to scrub anything though!
3. Remove the fuel feed hose by doing the following:
Now the manual calls for you to connect the J-34730-1A fuel pressure gauge to the fuel pressure connection. It states to wrap a shop towel around the fitting while connecting the gauge in order to avoid spillage.
I didn't have that tool and that puppy cost $213.58. Needless to say, I didn't rush out and buy it. What you basically do is connect this tool, attach a drain hose to it and bleed the excess fuel off into an approved container by turning a lever on the tool. Since I didn't have this tool, I got a bunch of paper towels ready for when I disconnected the fuel line. I had some fuel spillage when I did so and fuel remained in the fuel rails when I removed the manifold (I found that out when I pulled the manifold up off the car).
Thus, be cognizant if you have no way of relieving the fuel pressure when disconnecting the fuel line and have plenty shop towels ready!
Next, get plenty of shop towels and place them under the fuel line where it connects to the at the female connector of the fuel feed hose. You will have some fuel spillage here.
Remove the dust cover.
Then using your fuel line disconnect tool, separate the female connector from the fuel line by inserting the tool into the female connector, then push inward in order to release the locking tabs. The fuel line will then separate from the female connector of the fuel feed hose.
Clean both connectors. The manual calls for you to remove the fuel feed hose by disconnecting it at the other end. I didn't find this necessary and left mine connected to the car. The reason was probably so that you didn't damage that fuel line so either remove it or be very careful around it.
4. Cap the chassis fuel pipe and the fuel rail pipe in order to prevent possible fuel system contamination.
5. Check the fuel feed hose for any damage and replace if necessary.
Tools Needed
Now for the repair!
- Drive the front of the car up on some 2X12's.
- Using a low profile jack that I got from Harbor Freight, I center a 2X4 on the jack plate and run it under the front of the car.
- Once in place and lifted, I support the car with jack stands.
- Remove the overflow tank cap and get your safety glasses on. Remember, safety first!
- Once all of the coolant has drained, close the drain cock and lower the car. You can reuse your old coolant if you want to but if it wasn't changed recently, I don't know why you would. Don't be a cheap azz, buy some new fluid for your baby. Don't get the 50/50 stuff because you're paying for water, which is free (however, if you don't have access to distilled water, buy the 50/50 stuff). Other than that, buy the full strength stuff and dilute it with distilled water. You can use A 50/50 mixture of clean, drinkable water but use only GM Goodwrench® DEX-COOL® or Havoline® DEX-COOL® silicate-free coolant. It takes approximately 11.9 liters (12.6 quarts) to refill the cooling system.
- Disconnect the negative battery cable.
- Relieve the fuel system pressure by loosening your gas cap.
