after aquiring a tach drive, i rebuilt it and it ran great. (thanks to B2B) BUT when i timed it (vaccum advance pluged up) i got no mechanical advance. when the vaccum adcance was hooked up, i did get some advance, but not as much as i should be getting with both the mechanical and vaccum.
the previous owner of the distributor had some rotten rubber bushing on the mechanical advance limiter (which i tossed when during the rebuild). i changed this to a copper one from a Mr Gasket kit which still allowed the mechanical advance to move, but much less than before. can i run a dizzy with no bushing? or what else would you recomend i do
