1 - 15 of 15 Posts
i have two days to figure this geardrive thing out will it work in my 85 and not mess with knock sensors
I think you're beating your head against the wall. Why the hell would you want a gear drive anyway? Is this an all-out, high RPM race only engine?
If you are doing a gear drive for sound.... well... that's a lot of money and time for a sound!
How much are you paying for this pup?
They're popular with the street rod crowd around here, and the sound is the reason. Personally, that aspect of gear drives does absolutely nothing for me.
The loud one WILL mess with the knock sensor the quiet one is not foolproof but has been run with sucess
i'm installing a comp xe 268 not sure which type of gear drive or even if i should i just thought since i've torn everything down i'd get some input. on if i should or not it's the wine that i like .
"noisy" gear drives are only for carburated engines, or meckanical injection.
"quiet" gear drives can be run in efi situations. but have been prone to trip the knock sensor. I would call up the manufacture of the gear drive you desire and talk with a tec person. see if they have sucessfully installed them in efi applications similar to your set up.
its still a gamble tho.
a good timing chain should last a good while, before gaining slack.
my poor old pontiac block had over 1/2 inch stretch in its timing chain when I finaly pulled it. I was amazed it was still running when I pulled it. the cam could advance and retard it self about 20 or so deg. at its own will.
or beer
no seriously if you want whine just run about 3 qt's low on your tranny fluid ;)
superchargers whine and it gives you a bit of a power boost.
I like wine too. But if I liked whine, I'd still be married..... :lookinup:
blower whine is neat for about two hours, then you will try things like 90 weight oil in the front case, or staggered notches on the pulleys, etc to stop that d#^& noise...BTDT
1 - 15 of 15 Posts
