Ok, I changed the entire door speaker assembly , I won a set off ebay, I tried all 3 speaker assemblys, and they do the same, popping and cracking, so now I replaced the bose signal processor under the dash next to the column, still popping, so I guess it is the deck after all, Or is there something else it might be. Please help.
I am having the same kind of issue with my 99. Both right side speakers make loung crackle noises once in a while even when car not running. I switched speakers from other side and right side still noisey. Next i put in new signal processor and still noisey. I checked all plugs and wires and all seems fine. The only thing i can think to try next is HU.
Let me know if you figure anything out!
Did you all try to clean your records with a disc cleaner before letting the stylus touch it. That will cause clicking and popping also. While you're at it look for records recorded on virgin vinyl. Much less noise and cleaner sound.........well, that used to stop my noise problems.;)
