We are working on Mikes 1970 vette and have problem that we cannot seem to fix. The car has a 950mA draw and it is killing the battery. Everything is all new. You can make the draw go away if you remove the two wire plug on the alternator. We came up with another new alternator and this still did not cure the draw. The draw also goes away if you remove the clock, lighter, courtsey light fuse. We have pulled the plug on each gauge except temperature and still have the draw.
Any ideas or help would be greatly appreciated.
