Hi I was wondering if anyone could tell me where the fuel pump circuit in my 88 is grounded as I think I have a problem there.
Thanks
Allan
Thanks for the diagram but it doesn't help me to find the location of the ground that feeds the fuel pump. Are you certain this is an 88 as the wire colors look different as well?
Allan
it is typical Vette TPI pump circuit; colors may vary but circuit the same
Look at the fuel pump connector at tank; there is black ground wire there which is the ground shown in circuit diagram above
Thanks for the grounds diagram. I have pulled out the inner fender to look for the ground strap above the right rear wheel but can't see one there. I did find one behind the left rear wheel but it's not the one for this circuit. Anymore ideas?
Allan
