Extreme Rich problem causing missing 85 corvette advice?
Last week I drove it home to change the oil. After changing the oil I took compressed air and blew the engine off because it's been quite dry around here. After doing that I started it up to check oil pressure which was fine. Yet soon as I started the extreme rich problem started. It blows a combination of blue/black/Gray smoke constantly and misses. What I have done is as follows;
Compression check on all the cylinders which was even 235 psi on all the motor is new with 1400 miles
I have a dmm and have ohms all the spark plug wires which were in range going by the spec of 1000 ohms per foot
I have checked fuel pressure which is 42 psi, exactly what I set it a month ago
I checked the timing which is 10*, hasn't changed, I checked it with esc unhooked
I also changed the spark plugs to eliminate the possibility
I have checked the resistance of the injectors which are stock 85s they all spec 16-16.5 ohm, admitable I forgot the scale on my meter I was using
I have a OTC scanner, my dad was a previous mechanic and the data looks normal, and have no trouble codes.
I have had the valve covers off to check for broken valvesprings and valvetrain which is all fine.
I have checked all vacuum lines, but will be checking them again
Any advice is appreciated thanks guys
