I installed a new Dewitt rad. w/Fans, on a 80 L-48 with A/C
Those Fans are Loud and pull a lot Juice when running. I was thinking about reinstalling the stock fan and Shroud so I wont have to turn them on when running the A/C, I live in Ft.Laud. Fl. so there on all the time.
Will they fit? Anyone done the same or have comments?
If you bought a DeWitt's direct fit replacement radiator then yes your stock fan and shroud will fit back in as original.
The radiators are designed to be a direct factory replacement, so no changes need to be made. The electric fans are completely optional.
Why not use the electric fans?
Just use a Electric Fan Contoller!
SPAL makes a really nice programable unit for about $100. You actually set for when the fan goes on and off!
Or, just have 1 fan come on when the A/C comes on, instead of both of them.
