Hello,
Help, I'm adding Edelbrock Proflo rpm 3500 EFI and need to get the ecu cable portion through the firewall, is there any good locations to go through at?
Found that the Stoplight swith hose goes through the firewall and the person before didn't have it hooked up, what does it do? :huh:
Can I remove it and use its hole?
Any ideas I'd like to hear from you.
Thank you :buhbye:
Don
Thank you :buhbye:
Don
