1 - 14 of 14 Posts
Hey guys,
I'm currently pulling a few accesories off my present 427 while I accumulate parts for the new one. I thought while I'm in the neighborhood I'd clean up the flywheel (and pressure plate). I've only got about 10k miles on it, and it is nowhere close to needing a surfacing, but I'd like to "buff it up", as it were, before I eventually put it on the new engine. What methods or techniques have any of you guys used to freshen up the flywheel surface and appearance?
thanks,
Mike
assuming no grooves or damage, I would leave it alone for now, when you eventually use it again, give it a once over with 400 grit on a finish sander, nice flat thing like for cabinet work....store it and the PP with a coat of oil on it, not diffy lube, something like WD40...
works for me....
obivously you need get the oil off it before use....well.....:smack
The cost for a "kiss cut" is about $30 and is your best option. The sanders will work as well, but if it were me I'd bring it to a good shop and tell them to just kiss it,..... the flywheel that is.:laughing:
If you store for a long time do not use wd40 - it attracts dust which will hold moisture and I think it also has some chemicals in it that act like emulsifiers. The emulsifiers actually allow the penetrating oil to co-exist with water and you may get flash rusting.
I use it on my hand saws every time I use them. I wondered why with this stuff on them they were always rusted when I need to use them. Oh well.
While we are on the subject, is there a way to remove heat marks in the surface of a flywheel? I could replace the faceplate material but it still has lots of life left in it. Or is this bad enough to consider replacement of the face material?
Hey thats the setup that was in my wanted ad! :laughing:
Aluminum flywheel inserts arent supposed to be turned. The PP had some pretty bad hot spots on it as well. I would just use it until it dies. But thats just me :smack
You are correct on that one. I talked with the guy several times and checked on getting new face material. For the money, even if I have to replace the face material, it still does not come up to the price of the flywheel itself. So, I took the chance on it. Should help wake the LS up some.
No doubt it was a good deal. I just wanted something a little stronger. I actually picked up an LS7 setup for $200 shipped:partyon:
According to SPECs webpage, I should not have any problems with the strength problem. I don't think I will surpass 530 ft lbs spec allows for stage 2. If I do, then let the smoke show happen.:partyon:
1 - 14 of 14 Posts
