I already did cut the rubber thingy from on top of the spring. That is how it is lowered now. Honesty I only think it dropped it less than an inch.zelement said:Pat,
what Nasty C4 did is the way to really lower your front if you want it super low. That is the same way I did mine before I went to the coilover setup.
If you don't want it that low you can just not install the wedges, that will give you about another 1/2" lower than compared to the wedges.
I think I'll replace the wedges with the MAD urethane ones. Cuz I want LOOOOWWWWW.zelement said:you have to do both! If you want it low. You have to cut the rubber bumps off the spring then scrape off the stock wedges and either install the MAD wedges or no wedges.
