What are the symptons that your engine may have an issue with boiled fuel going into the carb?
always glad to help when i can:thumbsup:
these may help
http://forum.grumpysperformance.com/viewtopic.php?f=55&t=211
http://forum.grumpysperformance.com/viewtopic.php?f=55&t=635&p=849#p849
every time I read a thread like this its filled with guess work, and that's totally understandable, since we are responding to info provided but have no way to TEST, and ELIMINATE the potential source of the problem before moving logically thru a series of checks that will positively pin point the problems source.
probably 70%-80% of the time simply dropping back to the basics of doing a compression check,properly adjusting the valves, checking the firing order, reading the spark plugs, setting the timing, verifying top dead center and checking for vacuum leaks,verifying correct float levels,correct fuel pressure, correct voltage, polarity, and your grounds will give you a good indication of the engines condition
http://forum.grumpysperformance.com/viewtopic.php?f=50&t=609
