Hello,
I have a 98 vert. I am having intermittent fuel gauge failure. Sometimes it functions correctly and other times it just goes to E causing the CHECK GAUGE light to come on. If I turn the key off and back on again , the gauge resets to the F position then back for a normal startup then settles back to E when in the failing mode. Any idea on what I should try, trouble shoot or test to find out what is going on. Other than that, everything is cool. :huh:
Best Regards
Tony
There is a software update that also addresses this issue. You can only get it at the dealership. Before you actually pay any money to fix this problem, that update should be the FIRST thing you have done. Other than that, try the Gumout product mentioned in that other thread and post your results there. I am especially interested in seeing if your first bottle fixes the problem. Let us know.
