Found A Oil Leak Around Fuel Pump The Face Of The Pump Was Cracked
So I Went To Get A New Pump. The Oem Pump That They Sold Me Has The Fittings Pointing Toward The Frame
It Has The Outlet Pointing Toward The Back Of The Car
On Old Pump The Inlets Are Pointing Toward The Front Of Car And Outlet Is Pointing Toward Front To
How Are Fittings Supose To Go
Outlet Hose Is Foing To Be Close To Header If I Use New Pump
What Is A Goog Replacement Fuel Pump For 1971 With Zz4
I have a 73 SB and the description of your new fuel pump is the same as the one I have. To work with the factory style fuel line the output side of the pump needs a 90 degree fitting installed. With the fitting added the opening will then point more to the center of the car.
SBC pumps have the ports in different locations for different applications. I would check to see if you have the correct pump for your car. The std pump will work with that engine, you're goign with a carb correct? You should hard pipe it to the carb as well.
I Have A Holley 4150 Vac Sec What Would Be Advantatge Of Hard Lines
The Carb Is Dual Lines They Are Rubber
Advantage? Rubber lines are attacked by gasoline. Then they leak. Leaking gas + hot engine = fire. or more appropriatly on a Vette
F I R E
