thanks war,your help is apperci.>I fond that the fuse links that i was concerned about come off the selinoid of the starter,and there are 2,(make a note main feed lines to fuse box)I checked them today,and guess what,right ,they were bad .replaced in line fuse ,Houston we are A-OK. Thanks War,hoope that i can give the same some time to you ,and all DC crew sometimeWar Machine said:I'm looking in my 87 service manul, I know it's a different year but hopefully some things remained the same. :thumbsup:
I'm looking at the Power Distribution section of the electrical manual and it shows all 11 fusable links are behind or near the battery except 1 that's near the starter. There is a well detailed scematic here that shows all the fusible links for Power disribution, is there a specific component you want me to check out?
Thanks all.I talked to a good GM>tech.He told me to check link going into selinoid.Bingo thats where to problem was.This is the maim fues link to car.kenney said:Can any body tell me where the fusible main power link is.I looked in my haynes,and look no diagram.i belive that this is my problem,as i decribed in my other thread,help anyone:lookinup: :buhbye:
Kenney, that's great news. Glad you got it worked out.kenney said:Thanks all.I talked to a good GM>tech.He told me to check link going into selinoid.Bingo thats where to problem was.This is the maim fues link to car.
Hell yea get rid of it, was it trying to dismember your starter?kenney said:This is the maim fues link to car.
tony the main power links(2) are located a your selenoid.There should be 2 running along second power. feed to unit.they lookl like blisters,have to replace with new wire,and a fair amount of tape.Use solider to replace,makes for a better conection.Make sure you disconectt battery first!!!!!!!oldace84 said:Where are they located?
thanks
tony
