In searching for the fuel pump wiring I had to remove the dirver's side inner fender well. It's easy with the wheel removed. Approx. six or seven sheet metal screws and some fidgeting around and you have great acces. I think you may need to do this to see better what you are dealing with. Watch out for the door latch cable bracket, it has a plastic retainer which is delacate.:thumbsup:
