I am about to start working on obtaining the parts to build the following engine for my '00, lemme know what you think. my goal is around 600hp
402 LS2 short block from texas speed and performance http://www.texas-speed.com/shop/item.asp?itemid=684&catid=28
-wiesco -2cc flat top pistons
-callies 6.125" compstar rods
-callies compstar crank
-24 tooth reluctor wheel
-ls2 to ls1 conversion kit
trick flow genx 225cc cnc heads (will be upgrading springs because the ones the heads come with dont allow for enough lift for the cam) http://www.summitracing.com/parts/TFS-3060T001-C02/
LG G5X3 camshaft http://www.lgmotorsports.com/catalog/product_info.php?cPath=342_221&products_id=1509
melling high volume oil pump http://www.summitracing.com/parts/MEL-10296/
102mm FAST intake
nick williams 102mm throttle body http://www.lgmotorsports.com/catalog/product_info.php?products_id=2189&osCsid=be3
will be using arp studs where available, and arp bolts everywhere else
I'm actually considering something very similar. Wanting some more cubes under the hood! :partyon:
im with bryanthomas on this one also, Im looking for more cubes.....if you dont mind me askin, how much are the parts totaled up?
You dont really need to pay all that extra money for the ls1 to ls2 conversion parts.
just make sure that you use ls1 cam gears and the 3 extensions for the harness. i know two of them are the knock and crank sensor cant remember the other.
they way overprice what you need for the ls2 swap into a ls1 car.
this link goes into detail, everything you need to do.
http://www.ls2.com/forums/showthread.php?p=10084605
probably looking at over 8k easy. I know the 402 shortblock alone from texas speed is about 4500-5000 depending on accessories you add to it.
