As part of spring maintanence I plan to replace all the hoses in my 93 LT1 6 speed's cooling system. So far I figure I need:
front upper radiator hose
rear upper radiator hose
lower radiator hose
throttle body to heater hose T
throttle body heater hose
top water pump to T heater hose
T to heater box heater hose
bottom water pump to heater box heater hose
water flow control valve - inline heater hose
Have I missed anything? I don't want to be into the job and find out I need something.
thanks
Not real up on my LT stuff but that looks like you have them all. Did LT's have the oil cooler on them? IF so you'll want to do those hoses. They are under the motor.
No oil cooler that I'm aware of. I think that was only on the L98s.
