What's a good product to use for removing grease/oil from inner fenders of the engine compartment? Would it leach into the 'glass?
Supporting Vendor / Car Care Sponsor
Well, consider this advice completely partial, however, Adam's Polishes makes an 'All Purpose Cleaner' that will do the trick. Spray the compartment while dry, then for best results, use a soft bristle brush, like a Boar's Hair, and give it a once over. Blast clean with the hose, and you should be perfect. Still grease or oil remaining? Repeat steps above.
Here is a video doing just that: http://www.adamspolishes.com/t-Videos_DVD5_5.aspx
Hope this helps!
-Adam
