My 81 has 43k on her and is a 4-speed.
The clutch pedal seems on the somewhat hard side,free play is perfect 1-1.5" abd the tranny shifts smooth,and skipping and chatter.
I lubed all the linkage pivot points,as well as the cross shaft fitting.
No binding at all,just a pretty hard pedal effort.
Some say this is normal for a mechanical clutch with v8. Maybe the small clutch pedal makes it seem worse. Others I know say it is not.
Any advice,and or opinions etc. would be greatly appreciated.
Later, Ken
Hey Ken,
If you are accustomed to driving lets say, a Honda with a stick shift, then your Corvette clutch is going to feel like a U-Haul truck in comparison. Lots of these cars have had aftermarket performance parts installed too. I hope that helps!
Like D V 8 mentioned, the majority of newer cars have hydraulic clutch assemblies that make pedal effort nill. Yours is old school two foot effort. :D Especially if your running a heavy duty 11'...or 3 finger Borg & Beck style...or dual friction etc... Just get into the gym and build up those legs :laughing:
I have found that changing the clutch return spring can reduce pedal effort, but being very carefull not to go TOO soft.
Eddie
The factory clutch and some aftermarket clutches are not hard to depress. Try to see how another C-3 clutch pedal feels. One symptom of clutch failure is an increase in pedal effort over time.
Im wondering if the clutch failure is a factor,I dont think so as, the clutch has no chatter or slippage,only 43k all original.
I did get a new return spring,and am going to pop it on this weekend.
As far as the legs go thats no problem (I run 4 miles daily,6 times a week)
Its the slight discomfort on the ball of the left foot,(wearing New Balance running shoes most of the time) when depressing the clutch a lot.
Someone else suggested that the throw out bearing might be dry.
Ken
Ken
I would compare it to some other similar cars if you can as mentioned above. That's exactly how the clutch in my mother's car felt... just before I pulled it out and saw the bent fingers of the pressure plate that looked something like a crow's foot...
