1 - 9 of 9 Posts
I have one headlight that does'nt always want to close. I can close it manually so I don't think the gears are bad. Any ideas. :huh: :huh:
I'm thinking you may have a bad/dirty connection for the motor. Can you hear the motor running when you turn the headlights on and off?
-=Jeff=- said:
Have someone turn the lights on and off while you listen for the motor to run.
I am guessing it is the Delrin busings in the motor, they prbably need replacing. I don't think it is the Motor
The motors run because it always opens, does'nt always close tho. :( I was thinking maybe a bad connection.
Hey raid, I thought you and Pat were going to store it for me. :rolleyes:
do 88's HAVE delrin bushings? i'm not so sure
i would check all connections and the relay for that side
Extra Crispy
Mine was the relay
Mine did that......it would only 1/2 close.......I took the moter apart & replaced the gears, cleaned it & re glued a magnet that dislodged inside....works great now!:)
1 - 9 of 9 Posts
