oky doky, well since I need to get something done and my turn signal problem is turning into a fiasco, i have decided to move onto finding out what's wrong with the drivers side headlight. The passenger side headlight moves up and down and works fine, but the drivers side when the switch is turned on moves up a little (like 1 cm). If you push it up from under it, it won't click into place but goes to the top then moves down a bit and then stays there. When turning off the lights it moves down VERY slowly. So my question is, what most likely would cause this? All the linkages and springs seem fine, and the vacuum to the actuator feels similar to the pass side. I have been thinking about getting a vacuum gauge and see if there is any difference but I haven't gotten around to it due to working alot. So based on the information given, am I right to assume the actuator needs to be replaced? I appreciate everyones help!
