Have a 1975 and noticed that the headlights come on when you insert the key and turn to the accessorie or start the car. I changed the headlight switch but the headlights still stay on up or down. I don't think it's the headlight switch because everything works as it should from the switch. PLEASE can anyone help this is driving me nuts. Thanks.
You might have a chaffed wire that's causing a short when the key is on. One simple way to find it is to turn the key on and start pulling fuses one at a time and have someone stand in front to tell you when you find the short problem. Hope you find the problem and it's a simple fix.
